How to proceed from WIFI screen
Hi
I buyed Nexus 10, and tried use it
But already in beginning face a problem
When i turn on tablet i see Welcome screen
After choosing language- English and pressing Start button, i go to Wi-Fi connection screen
And here i am stuck
I select Wi-Fi connection. and it is connect, but i still stay in this page
Somebody knows what i do wrong?
Thanks
Re: How to proceed from WIFI screen
Is there a continue button or arrow? Or you should be able and go back skip signing in and sign in when u get it past the start
Nothing
I can't skip this screen because in Welcome screen there are only one button - start, that proceed me to WiFi page.
Closed:) My mistake with connections. Thanks
looks good,thank you !![Only registered and activated users can see links. Click Here To Register...]
I am having exactly the same problem and it's not clear how it was solved. I get to the "Select Wi-Fi" screen (and there's no option but to go here) and I select my network. It doesn't appear to connect, which may be the problem, but I can't *do* anything else. There are no other options. I am stuck and my "nexus 10" is now a brick. I can restart and get back to where I am, but that's it.
Wifi is at the moment open. I could set it to something else if that helped. Network is detected - appears in the list - connect is an option and no complaint is made that it can't connect. Just nothing happens.
Francis
