Results 1 to 6 of 6
- 12-20-2012, 06:30 AM
Thread Author #1
How to proceed from WIFI screen
Hi
I buyed Nexus 10, and tried use it
But already in beginning face a problem
When i turn on tablet i see Welcome screen
After choosing language- English and pressing Start button, i go to Wi-Fi connection screen
And here i am stuck
I select Wi-Fi connection. and it is connect, but i still stay in this page
Somebody knows what i do wrong?
Thanks - 12-20-2012, 06:37 AM #2
- 12-20-2012, 06:44 AM
Thread Author #3
- 12-20-2012, 07:25 AM
Thread Author #4
- 12-20-2012, 08:31 PM #5
- 04-22-2013, 05:25 AM #6
Re: How to proceed from WIFI screen
I am having exactly the same problem and it's not clear how it was solved. I get to the "Select Wi-Fi" screen (and there's no option but to go here) and I select my network. It doesn't appear to connect, which may be the problem, but I can't *do* anything else. There are no other options. I am stuck and my "nexus 10" is now a brick. I can restart and get back to where I am, but that's it.
Wifi is at the moment open. I could set it to something else if that helped. Network is detected - appears in the list - connect is an option and no complaint is made that it can't connect. Just nothing happens.
Francis
Droid - How to push from Corporate Lotus Notes?
By Android Newbie in forum Motorola DroidReplies: 21Last Post: 06-19-2012, 04:44 AM -
How to you jump to settings from home screen?
By iastonish in forum Verizon Galaxy NexusReplies: 4Last Post: 12-15-2011, 02:02 PM -
How far away from Wifi router can you get?
By whitenack in forum General Help and How ToReplies: 3Last Post: 06-08-2010, 12:43 AM -
Plan on Upgrading to bigger Micro SD, how to transfer from old?
By dfine1966 in forum HTC EVO 4GReplies: 2Last Post: 06-07-2010, 12:32 PM -
How To- Go from stock to custom 2.1
By Andrew Ruffolo in forum HTC Hero Rooting, ROMs, and HacksReplies: 1Last Post: 04-12-2010, 02:39 AM
Reply
My mistake with connections. Thanks
