1. Cveti Yo's Avatar
    Hello guys!
    Today I was playing on my phone and when my battery was about 5% I turned it off. When I put it on charge and turned it on almost all of my apps (actually all that are on the sd card) just stopped. EG:Unfortunately, avast! Mobile security has stopped. Some of them are even missing.
    And also my phone is kinda slow (it has 1gb ram)
    Can someone help me,please?
    12-25-2012 11:58 AM
  2. still1's Avatar
    reboot again. but this time charge it full and let it come back up full before using.
    12-25-2012 12:15 PM
  3. Cveti Yo's Avatar
    I already started re-installing the apps. Some are working normally,others are a bit slower and the rest are still giving me the 'unfortunately' error. Anyway I'll charge it and reboot it again. Thanks for the quick response.
    12-25-2012 12:25 PM
  4. DroidXcon's Avatar
    Try reprint into recovery and wipe cache Partion. Then restart. It should take several mins.
    From my Galaxy Note 2 via Tapatalk
    12-25-2012 12:50 PM
  5. Cveti Yo's Avatar
    Thanks for your reply, but I don't have any idea how to "reprint into recovery and wipe cache partion" so can you please explain it? Thanks in advance!
    12-25-2012 12:56 PM
  6. DroidXcon's Avatar
    I meant reboot not reprint lol....with the phone off ,press and hold Home+Vol down + power keep holding and this should take you into a recovery screen. From this menu use the option to wipe cache partion. Since I don't know which Carrier your phone belongs to it is hard to know for sure if this is the procedure but it should be close
    12-25-2012 01:11 PM
  7. Cveti Yo's Avatar
    ugh im pretty much desperate righy now,so
    12-25-2012 01:45 PM
  8. DroidXcon's Avatar
    Says it's a private video
    12-25-2012 01:50 PM
  9. Cveti Yo's Avatar
    Oh sorry, my bad. I edited it so you should be able to see it now
    12-25-2012 01:57 PM
  10. DroidXcon's Avatar
    What phone is this?
    12-25-2012 02:07 PM
  11. Cveti Yo's Avatar
    What phone is this?
    Newman N1
    12-25-2012 02:08 PM
  12. DroidXcon's Avatar
    Newman N1
    I don't know enough about this phone. All I could find that is close to a guide is this http://jimbi.net/newman/
    Cveti Yo likes this.
    12-25-2012 02:17 PM
  1. Some apps disappearing after reboot
    By Enderend in forum HTC EVO 4G LTE
    Last Post: 05-12-2013, 08:16 AM
  2. camera app problems after lhe update??
    By The Sim in forum Verizon Galaxy S III
    Last Post: 10-21-2012, 09:16 AM
  3. Apps missing after reboot
    By montenell in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 01-13-2012, 12:18 PM
  4. Talk App Problem after GB
    By losvaldez in forum Verizon Droid Incredible 2
    Last Post: 07-13-2011, 08:05 PM
  5. App Problems After Hard Reset
    By bonanzabucks in forum Sprint Epic 4G
    Last Post: 09-18-2010, 01:38 PM
