1. terminally_chilled's Avatar
    My mother gave me her Samsung Galaxy S GT-I9000M. I was having problems with the sound and other things, so I decided to do a factory reset. Well..
    1. Don't have Google Play. Instead, 'Market' is there (haha). When I tap it, it brings me to the terms & services of Google Play but there's no way to accept them or get past them in any way. I can't open Samsung apps either, don't know why.
    2. I can't do a firmware update at all. Samsung Kies tells me my phone can't do it through the program (?) and there's no option on the phone itself.
    I'm just very annoyed right now. I don't know much about these phones, so any help is greatly appreciated. Happy Holidays.
    Edit:
    3. Samsung Kies detects the device but, when I tried to sync music to the phone, it said "device not responding".
    I'm about ready to throw this thing out the window.
    12-25-2012 12:28 PM
  2. DroidXcon's Avatar
    Edit:
    Which phone is this I can't tell by the model number. What carrier. When you did the factory reset was it from recovery or from the settings options?
    From my Galaxy Note 2 via Tapatalk
    12-25-2012 12:56 PM
  3. terminally_chilled's Avatar
    Carrier is Bell. Reset from factory reset in settings.
    Phone:
    12-25-2012 01:13 PM
  4. DroidXcon's Avatar
    Phone:
    http://cdn.slashgear.com/wp-content/...GT-I9000_3.jpg
    with the phone off ,press and hold Home+Vol down + power keep holding and this should take you into a recovery screen. From this menu use the option wipedata/factory reset also wipe cache partion. Not sure if this is the procedure for your phone but it should be close.
    12-25-2012 01:18 PM
  1. Replies: 14
    Last Post: 05-28-2015, 04:05 PM
  2. Questions about Factory resetting phone
    By jontalk in forum AT&T Galaxy S III
    Last Post: 11-02-2012, 08:03 PM
  3. After factory reset, phone's gone....
    By mmkisa in forum Motorola Droid X
    Last Post: 07-21-2012, 08:04 PM
  4. Two factory resets and still problems.
    By flipster in forum Motorola Droid X
    Last Post: 10-01-2010, 01:48 PM
  5. Why does this phone have so many problems?
    By bigk in forum Verizon Droid Incredible
    Last Post: 05-27-2010, 01:10 AM
