Results 1 to 3 of 3
- 12-26-2012, 09:04 PM
Thread Author #1
Help Needed: Android Car Infotainment System
Hi,
I'm newbie on the Android and recently bought a car in CHINA and it came with a Android powered dvd/navigation/fm/player/etc.
I have it already connected to a Mobile WiFi over the China Mobile via a USB WiFi Dongle and downloaded some apps. Some apps I use are blocked in china (TuneIn Radio, Pandora, etc), and i'm looking for a way to have a VPN on it.
The thing is that the manufacturer of the device removed the VPN network settings, so I can't connect (or it is absent on the Android 2.3.4 )
Question: is there a way to install some kind of VPN Client on this android? I already have a paid VPN Account and use on my apple devices.
Any help will be appreciated,
Thank you
Rodrigo - 12-27-2012, 12:29 AM #2
- 12-27-2012, 02:57 AM
Thread Author #3
Help! Need Android tablet that runs Sketchbook Pro
By Coder88 in forum General Help and How ToReplies: 0Last Post: 11-19-2012, 02:35 PM -
Moving from WebOS to Android... help needed
By tommygun in forum General Help and How ToReplies: 7Last Post: 12-16-2011, 04:31 PM -
Android Infiltration - Check Update Help Needed
By newtronco in forum Beta RequestsReplies: 0Last Post: 11-22-2010, 09:48 PM -
Need Android help?
By androidzone in forum General Help and How ToReplies: 0Last Post: 08-15-2010, 07:08 PM -
Anyone have CarFax? (Car buying help needed)
By NVR2ND in forum The Android Central LoungeReplies: 0Last Post: 06-29-2010, 12:19 PM
Reply
