1. Yanks1113's Avatar
    My younger brother got a tablet for Christmas. It's called a "yeahpad" and it's made by some Chinese company. He downloaded the flixster app to watch movies on, but when you go to watch something, it said the device is rooted and for security reasons, you cannot watch the movie.
    I downloaded the es file explorer app, deleted the su file from the xbin (There wasn't an su file in the bin folder). Then I went back to the app folder, but there isn't a super user file.
    Now it won't let me check the box for root explorer, and even though I don't want to, it won't let me uncheck the mount file system.
    Someone then suggested I download the ota root keeper app.
    Tried ora root keeper, but it says my device isn't rooted which doesn't make sense because flixster keeps saying it is rooted...
    All my brother wants to do is use his Flixster App! I have no idea what to do next, please help!
    12-27-2012 08:58 PM
  2. still1's Avatar
    1. root again, since you deleted su file
    2. I assume you are using super user. in super user there is an option to temp unroot.
    this will make flixter app work.
    if you want root back just enable root in super user.
    12-28-2012 12:47 PM
  1. Need help to Unroot EPIC 4G Touch FH13
    By neocromater in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 12-04-2012, 09:17 AM
  2. Need help to unroot Atrix 2
    By Gracie100 in forum AT&T ATRIX 2
    Last Post: 02-12-2012, 11:06 PM
  3. i need help! an unrooted nook color wont work right! please help
    By 03032008 in forum Barnes & Noble Nook Color
    Last Post: 09-19-2011, 09:06 PM
  4. NEED HELP!!! Just unrooted phone but its on 2.1
    By xfactor99 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-01-2011, 04:00 PM
  5. Need help on unrooting Evo 4g
    By deathvalley in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 02-21-2011, 10:13 PM
