Re: Upgrade and file problem
What device are you using?
Upgrading from gingerbread (2.x) to ice cream sandwich (4.0) on different manufacturers devices can lead to differing options when it comes to saving files and such.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
Its a Samsung T989 T mobile
try this. settings-->storage-->menu(three dots)-->USB mass storage--> check the one with USB or something.
the files and folder will showup on the PC.
