Results 1 to 4 of 4
- 12-30-2012, 03:02 PM
Thread Author #1
Upgrade and file problem
Hi guys,
I upgraded my operating system today from a gingerbread to ics 4.0.4. Everything seems to be working fine other than in the files menu usbStorage does not show up (where all my pics and videos are), however when i connect to my pc and open the removable disk drive (J
it shows up there and the files inside the folder are there too.
Any assistance would be greatly appreciated
Thanks - 12-30-2012, 03:10 PM #2
Re: Upgrade and file problem
What device are you using?
Upgrading from gingerbread (2.x) to ice cream sandwich (4.0) on different manufacturers devices can lead to differing options when it comes to saving files and such.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums - 12-30-2012, 04:19 PM
Thread Author #3
- 12-31-2012, 08:33 AM #4
try this. settings-->storage-->menu(three dots)-->USB mass storage--> check the one with USB or something.
the files and folder will showup on the PC.
Warranty just Expired so I decided to root my Skyrocket and Upgrade to Jelly Bean...and had problems
By zgibbyson in forum Skyrocket Rooting, ROMs, and HacksReplies: 3Last Post: 11-20-2012, 10:35 AM -
Internal Memory consumption - hidden files and other problems
By betsha in forum General Help and How ToReplies: 2Last Post: 02-23-2012, 01:07 PM -
Media File Problems (ringtones and media player)
By jcochran1977 in forum Verizon Droid ChargeReplies: 4Last Post: 07-17-2011, 09:11 PM -
sence ui location and temp problem
By tada1096 in forum HTC Droid ErisReplies: 9Last Post: 05-10-2010, 09:15 AM -
Twitter apps and notification problem
By mo-bile#ac in forum Android ApplicationsReplies: 6Last Post: 02-04-2010, 01:02 PM
Reply
