Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By still1
    kenyee's Avatar
    Posts
    Global Posts
    288 Global Posts
    Default How to minimize data over wifi hotspot?
    What I'd like to be able to do is:
    if I'm connected to a specific wifi AP (my prepaid hotspot),
    1) turn off autoupdates from the Google Play app
    2) turn off data for all apps except the foreground app
    3) or let me decided which apps I want to allow to transfer data when connecting via that hotspot
    This is to minimize costs associated with using that prepaid hotspot, but the same concept could apply for people who have limited data bandwidth per month.
    I'm using Android 4.1 on a Samsung S3 if it matters. I was hoping to find an app that would do all this, but it'd most likely need root access
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Default Re: How to minimize data over wifi hotspot?
    Tasker can do that and I am pretty sure you do not need to use root to do most of what you are saying.
  3. #3
    there is a simple way but have less control.
    1. In google play setting set download only by wifi.
    2. restrict background data for apps. go to settings-->data usage-->click on app-->restrict background data
    now go to setting-->data usage-->menu(3 dots)-->mobile hotspot-->check the wifi that is mobile hotspot.
    now that wifi will be considered wifi hotspot and will restrict data just like any data usage.
    or you could use tasker app.
    Thanked by:
    kenyee
    kenyee likes this.
    kenyee's Avatar
    Posts
    Global Posts
    288 Global Posts
    Quote Originally Posted by still1 View Post
    I think that's what I really want. According to the Android 4.1 Jelly Bean docs on Google's site, it'll disable background data when connected to that wifi hotspot.
    I couldn't find anything in Tasker that lets me do what I want...it'll shut down mobile data based on certain events, but that's not what I want to do since I have no mobile data. I'm trying to minimize the amount of data going over my wifi hotspot and the setting you mentioned should do it. Thanks :-)
  1. Replies: 0
    Last Post: 11-16-2012, 02:53 PM
  2. How-to: Syncing music over wifi from iTunes
    By Kyle Gibb in forum General Help and How To
    Last Post: 11-28-2011, 02:03 PM
  3. Using public wifi - how to protect data?
    By itsmejson in forum Verizon HTC Thunderbolt
    Last Post: 08-27-2011, 04:27 PM
  4. how to get fast internet wifi hotspot
    By diablito_192003 in forum HTC EVO 4G
    Last Post: 06-12-2011, 12:33 PM
  5. Replies: 11
    Last Post: 02-02-2011, 03:02 PM
