1. April Dawson's Avatar
    For some reason, my razr will not play on the auxiliary cord anymore. It was working, then just stopped one day. It might have been when i started using my 32gb sd card in it. Help!
    01-01-2013 10:14 PM
  2. Mooncatt's Avatar
    Do you mean auxiliary cable as in the one you could plug into the headphone jack to listen to it through the stereo? And what exactly do you mean by it stopped working? I'm guessing you mean you aren't getting audio fed to the stereo, which could likely mean pocket lint in the jack preventing a good connection.
    01-02-2013 04:31 PM
  1. DROID RAZR HD appears in GLBenchmark
    By irkan in forum Droid RAZR HD
    Last Post: 07-25-2012, 08:56 PM
  2. PhoneArena: DROID RAZR HD appears in Cellbrite
    By Ry in forum Droid RAZR HD
    Last Post: 05-30-2012, 03:20 PM
  3. Replies: 1
    Last Post: 04-01-2011, 05:28 AM
  4. Will Droid Incredible work in Antigua??
    By krDroid in forum Verizon Droid Incredible
    Last Post: 08-12-2010, 03:35 PM
  5. Droid vs AMOLED screens in daylight / car use
    By jlh#AC in forum Motorola Droid
    Last Post: 04-09-2010, 04:38 PM
