Results 1 to 8 of 8
    Default apps not working, data resets after restart.
    Hi everyone. .
    I am having a problem with my galaxy note 2, jellybean 4.1.2, rooted
    After I restart my device, some apps stops working, when I clikc them, it says unfortunately, the app XXX stopped working.. with no report option.
    Also, some apps that still working, their data just get reset.. like I have never opened them..
    This is really annoying me alot..
    I tried a factory reset and flashing new jellybean version (4.1.2) but I am still having this problem.. anyone can tell me whats happening? It's like the device is not loading the apps after restart or what exactly?
    Please anyone could help me?
    Note: no matter where apps are coming from (play store, amazon appstore, others) they just stop working.. and I will have to re install them..
    Please helpp this is frustrating..
  2. #2
    srkmagnus's Avatar
    Posts
    ROM
    Calkulin 2.7/Desperado
    Default Re: apps not working, data resets after restart.
    Are you using a custom ROM or a stock, rooted version?
    Are apps being loaded onto the external sd card rather than the internal sd card?
    Stock one..
    Internal storage.. I cant move apps to external SD anyways, unless using directory bind which I dont use
  4. #4
    srkmagnus's Avatar
    Posts
    ROM
    Does this happen immediately after factory reset or once you get apps installed? It could also be an issue caused by a bad app. If this is the case, factory reet and re-install apps one at a time paying close attention to when the problem occurs and what app may have been installed around that time.
    All this happens after I restart my device.. just a normal restart.. they dont work after the restart so I will have to re download them..
    I have tried to factory reset but it didnt help to solve this problem
  6. #6
    srkmagnus's Avatar
    Posts
    ROM
    This seems to be a device specific issue and perhaps should be moved to the appropriate forum by a Moderator for more visibility by persons with the same device. Hope you are able to get this sorted out.
    Thanks for trying...
    Anyone can help?
    This is only happening on my note 2.. S3 is working fine.. but I dont use S3.. I like note 2 more
  8. Thread Author  Thread Author    #8
    Any idea of which package might have to do with this? Maybe it has been deleted some how.. any ideas?
  1. engadget app not working after JB update
    By choclab1 in forum HTC EVO 4G LTE
    Last Post: 12-18-2012, 07:19 AM
  2. wifi hotspot app not working after s3 update
    By dfb8085 in forum Samsung Galaxy S3
    Last Post: 10-03-2012, 06:27 PM
  3. Gmail app not working after CM7?
    By jkm2282 in forum Inspire Rooting, ROMs, and Hacks
    Last Post: 05-13-2012, 12:18 PM
  4. Apps not working after update..
    By MAGiK9 in forum Samsung Galaxy S II Skyrocket
    Last Post: 11-26-2011, 05:44 AM
  5. ESPN Radio App not working after Froyo update
    By stevied3 in forum Android Applications
    Last Post: 08-12-2010, 04:27 PM
