1. TheSkipIt's Avatar
    The Note 2 is pretty much my first android smartphone, so far it's great. I just wanted to know if the Data Usage counter thing in the settings section counts ONLY mobile usage (3g/4g/etc) or does it also include wifi?
    So far I've only been using wifi for all internet purposes and the counter is up to about 730MB. I've been downloading quite a few apps from the Google Player market, but that was all through wifi, so if the counter IS counting wifi then it would make a sense.
    I just need a clarification, so a super straight answer would be great without much/any technical details. Sorry, I'm simple like that in the brain.
    01-04-2013 01:04 AM
  1. auto disable/enable wifi/data connection on Galaxy Note 2
    By sonyscaria in forum Samsung Galaxy Note 2
    Last Post: 12-31-2012, 11:47 AM
  2. Replies: 9
    Last Post: 11-18-2012, 10:32 PM
  3. Replies: 4
    Last Post: 11-15-2012, 02:32 AM
  4. galaxy nexus extreme data usage
    By danarmitage1898 in forum Google / Samsung Galaxy Nexus
    Last Post: 06-10-2012, 02:47 PM
  5. AT&T data problem on Korean Made Galaxy Note
    By BaLs in forum Samsung Galaxy Note
    Last Post: 01-02-2012, 11:20 AM
