- 01-04-2013, 06:00 AM
Thread Author #1
Density Changer!! Help!!
Hi,
I have a serious problem and I want you help.
I wanted to change the size of my icons, so that more of them could fit on the screen. So I download LCD Density Modder and Increased the amount to 160. After I booted my phone, my screen got zoomed in instead of decreasing. Now I cant even type up my password cause the numbers can't fit in the screen. I have no access to my phone because my phone is locked. Btw, I have a Samsung Galaxy Fit S5670 (rooted) . I am a total noob at this, so please help me!!! - 01-04-2013, 07:25 AM #2
Odp: Density Changer!! Help!!
Thats because dencity info in system decides which graphics resolution to use in order fit graphics in specific screen size, system thinking that it deals with higher dencity it delivers higher resolution graphics that look big real dencity of your real screen dencity. So you need to deincrese dencity insted of incresing, this way system will place lower resolution graphics that will be smaller
- 01-04-2013, 09:22 AM
Thread Author #3
Re: Odp: Density Changer!! Help!!
I fixed it after a FDR, which removed the password protection. But the density was the same, so I opened the LCD Density Modder and changed it after a long struggle. Hopefully everything is fixed, thanks for the reply, Shadowriver, now I understand.
- 01-04-2013, 08:02 PM #4
- 01-04-2013, 08:15 PM #5
Good to see you got it fixed. As Peacen1k said, Apex launcher will allow you to change the icon size, as will other launchers. Launchers can also allow you to change the number of rows and columns on the home screen to fit more apps.
Density changer apps
By jedidude75 in forum Android ApplicationsReplies: 0Last Post: 09-10-2011, 01:57 PM -
LCD Density Changer
By DoesItMatter in forum LG Optimus S Rooting, ROMs, and HacksReplies: 20Last Post: 08-26-2011, 10:14 AM -
Here is the LCD Density Changer app
By google123 in forum Motorola Droid ProReplies: 2Last Post: 05-24-2011, 02:05 PM -
LCD Density changer
By sicario666 in forum Thunderbolt Rooting, ROMs, and HacksReplies: 2Last Post: 05-18-2011, 07:36 AM -
Help evaluate a voice changer
By petkish in forum Beta RequestsReplies: 5Last Post: 03-04-2011, 10:10 AM
Reply
