i have a note 2 and the battery doesn't list any other apps even if i go on fb and netflix for hours all it shows is screen battery usage
[Only registered and activated users can see links. Click Here To Register...]
bonus : it adds to 102% *** well
Printable View
just let it die and recharge. it will recalibrate the battery
Are you using fb and Netflix while discharging? Check the stats while no longer charging and after using these apps, see what it says.
