1. jove123's Avatar
    my battery to my samsung galaxy s2 is dying within 3 hours and all im doing is talking i just bought it so what could be wrong? what are my options
    Sent from my SPH-D710VMUB using Tapatalk 2
    01-06-2013 02:19 PM
  2. Shadowriver's Avatar
    Talk takes power too, but if its really short then should be then it means battery is dying, which is normal thing, on each charge battery holds less and less, so cure here would be replacement of battery
    01-07-2013 12:37 AM
  3. maskedjackalxx's Avatar
    I was having the same problem. Did a reset and everything was kosher again. Just remember to back up your phone. I didn't and lost a bunch of contacts.
    01-08-2013 08:06 AM
  1. Just pushed stock battery over 24 hours on single charge
    By j.smilie in forum Motorola Droid X
    Last Post: 11-22-2010, 06:56 PM
  2. battery dieing to quick..
    By giggalz41 in forum HTC Droid Eris
    Last Post: 09-04-2010, 11:58 AM
  3. What's the point of 4G if the Battery Dies?
    By danielkogan in forum HTC EVO 4G
    Last Post: 06-25-2010, 01:21 PM
  4. Replies: 24
    Last Post: 02-23-2010, 12:18 PM
  5. What happened? Battery died after 3 hours
    By csiguy1 in forum Motorola Droid
    Last Post: 11-28-2009, 02:47 PM
