Results 1 to 4 of 4
    mrsteve0924's Avatar
    Posts
    Global Posts
    4 Global Posts
    Default battery consumption
    Recently bought a Polaroid PMID701C tablet. I was looking for that battery consumption graph that is on most android phones/tablets. The one where it shows which apps and hardware are consuming the most power. i couldn't find it and gave up. until one day when a low battery warning appeared on the screen. usually i cancel it, but this one time i clicked OK and it brought me to the battery consumption graph i was looking for.
    seems to be the only way i can access it. i understand that this tablet is entry level, but shouldn't i be able to get to this without having to wait for a low battery warning?
  2. #2
    Default Re: battery consumption
    settings-->battery
    Posts
    Global Posts
    4 Global Posts
    would you believe their is no battery option in settings?
  4. #4
    Default Odp: battery consumption
    They probably changed settnings application, but there possibility they didnt remove it, there intent triggering this setting ACTION_POWER_USAGE_SUMMARY, or try to find settings activity from activity list. Try to download intent caller and triggering that intent if you want it so badly and you really cant find it. You might find some equiclent on google play too.
  1. Maps app battery consumption
    By adamtalife in forum HTC One X
    Last Post: 07-13-2012, 12:15 AM
  2. stucked camera and battery consumption
    By Gianko in forum HTC Desire
    Last Post: 05-23-2012, 08:24 AM
  3. Excessive battery consumption?
    By strudel in forum ASUS EeePad Transformer Prime
    Last Post: 01-31-2012, 08:45 AM
  4. GO Launcher EX and battery consumption
    By m a x i m u s in forum HTC EVO 4G
    Last Post: 09-13-2011, 05:45 PM
  5. Polling vs. Pushing... Battery Consumption?
    By ellje in forum Verizon Droid Charge
    Last Post: 06-03-2011, 12:47 PM
