Replacement phone, Google rest or?
My replacement inc2 will arrive tomorrow, I'm prepared to root and flash and restore my nandroid. However, what do I do so Google knows it's a replacement and not a new device? This is my first hardware replacement, thanks!
Re: Replacement phone, Google rest or?
Whenever you first start it up, there should be an option to restore your Google account to your device. What this does, is it re-installs the apps you previously had, and logs you into your Google applications with your email.
what difference does it make if google knows its a replacement or a new device? i guess you are trying to make sure your new device get replaced in play.google.com
