Results 1 to 3 of 3
    Default Sd card movies
    Ok. My question is can you load the digital copy movies that come with dvds onto windows media player on your pc then copy onto your sd card? Is it mp4 format or an unsupported file type? Or are the digital copies strictly for itunes and psp?
    sent from Galaxy Note 2
    Razr ics rooted
  2. #2
    Default Re: Sd card movies
    Digital copies are DRM protected, so you can't just transfer them to your SD card and play them on your device. Typically, you first have to decide if you're going to use it on iTunes or WMP--once you've made that choice, you can't go back. If you choose WMP, then you can watch the digital copy on your computer with WMP, but unfortunately you still can't transfer that digital copy to your device (unless it's an older device that's PlaysForSure compatible, a compatibility protocol that Microsoft abandoned a few years ago).
    As a workaround, you can get a video ripping program like Tunebite by Audials (which is what I use) that gets around the copy protection by exploiting a loophole in the laws--it will play your DRM protected video on your computer using WMP, and record it in an analog fashion into a new file (with many choices of format). You can then move that unprotected file onto your device and watch it.
    I think these days, movie companies are no longer including digital copies on the DVDs--instead, you go to a website and enter a code, and then you can download the DRM protected video (which should still be playable on WMP and therefore recordable using Tunebite). More and more movies are also being made available using an Ultraviolet account for streaming.
    Laws are so stupid. I bought the movie and own the rights to it. I should be able to do whatever I want with it as long as it stays in my possession. Technically if I own the movie, I can pirate it online legally since I own the rights to that movie, correct? It might just be easier to download in mp4 off Pirate Bay
    Razr ics rooted
  1. Movies to SD Card
    By ej in forum Verizon HTC Thunderbolt
    Last Post: 05-16-2011, 04:27 PM
  2. Download movie from PC to Micro SD card ?
    By Stealth_Ghost in forum Motorola Droid X
    Last Post: 10-25-2010, 08:52 PM
  3. Transferred movies to SD card, won't play
    By RobertInCypress in forum AT&T Captivate
    Last Post: 08-06-2010, 01:05 PM
  4. SD Card plays movies with NO sound
    By rlrusso21 in forum AT&T Captivate
    Last Post: 07-26-2010, 12:34 PM
  5. Can I format my SD card and add music/movies before my phone arrives?
    By Cichlid in forum Verizon Droid Incredible
    Last Post: 06-01-2010, 07:43 PM
