Results 1 to 7 of 7
    Default Changing Status and System Icon colour?
    Hi all.
    Sorry, bit of a n00b with Android hence the question.
    I have a Galaxy Nexus running JB 4.2 and I've started playing around with (basic) customisation. Is it possible to change the colour of the Status and System Icons at the top of the screen from the default blue? Preferably to white. I have a nice dark look going courtesy of sammyycakes and others, the blue spoils it a bit.
    Again, probably a dumb question but there you go.
  2. Thread Author  Thread Author    #2
    Default Re: Changing Status and System Icon colour?
    Anyone?
  3. #3
    Default Odp: Changing Status and System Icon colour?
    Only by root access, you got it?
  4. #4
    Default Re: Odp: Changing Status and System Icon colour?
    not without a root and a mod.
    Ah, no. Unfortunately not. I had a nasty feeling someone might mention the 'r' word.
    Well I'm sure it's something I'll get around to but thanks to both of you for taking the time.
  6. #6
    I use StatusBar+ to do it without rooting.
    Here's the Play Store link-->
    Thank you. I'll look into that.
  1. Font color change or App for S3 widgets and apps icons?
    By oldAGE in forum Verizon Galaxy S3
    Last Post: 08-06-2012, 12:51 PM
  2. Changing Status bar icons
    By 3ibs in forum Google / Samsung Galaxy Nexus
    Last Post: 03-09-2012, 09:23 PM
  3. Change your boot animation and battery icon
    By gunnermike53 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 02-06-2011, 07:27 PM
  4. Earth from moon and browser icon overlay...
    By thatguychuck in forum Wallpapers, Ringtones, and Themes
    Last Post: 01-25-2010, 11:39 PM
  5. Dock changes ringtones and goes silent?
    By evanthx in forum Motorola Droid
    Last Post: 12-14-2009, 10:45 AM
