1. conman1395's Avatar
    The weird thing is, I haven't even used it. All I've done is install it and but it's using 10% of my battery. There only thing using more is the screen. Can anyone explain this? And if so is there a way to fix/stop this?
    01-14-2013 06:42 PM
  2. still1's Avatar
    settings-->apps-->All apps[extreme right]-->netflix-->clear data/cache
    01-14-2013 10:05 PM
  3. Laidir88's Avatar
    Clearing data and cache didn't solve anything for me.
    The netflix app is using 14% of my battery.
    Device:
    Samsung Note II-16GB
    01-15-2013 01:06 AM
  4. DroidXcon's Avatar
    We need more info then 10% of your battery. Those percentages are not based on 100% of your battery. So when you say it used 20% you need to tell us what percentage is left on your battery Aswell.
    From my Galaxy Note 2 via Tapatalk
    01-15-2013 01:12 AM
  5. conman1395's Avatar
    Well I was not so much concerned about the actual 10%. I was more concerned as to why, other than the screen, Netflix was using the most battery. The reason this is brought to my attention is because I had been using many other applications and I have not even opened Netflix. All I have done is download it.
    Sent from my DROID RAZR using Android Central Forums
    01-15-2013 11:57 PM
  6. still1's Avatar
    Device:
    I would call that a lie.
    01-16-2013 07:47 AM
  7. Shadowriver's Avatar
    Why? Deleting data and cache usually cause more resource usage as it need to reconstruct whole thing or else what you really wanted is to reset configuration
    01-16-2013 02:55 PM
  8. DroidXcon's Avatar
    Because it's not an app that would take up 14% there is no way its running on iys own
    01-16-2013 03:12 PM
  9. Shadowriver's Avatar
    You forget about services that can start on boot up. Thru i dont see info on behavior like that with Netflix
    01-16-2013 03:14 PM
  10. DroidXcon's Avatar
    It has no reason to do anything on its own. It doesn't even check for updates on its own.
    01-16-2013 04:46 PM
  11. Shadowriver's Avatar
    Well i never seen netflix in action, so i dont know ; p but lot of apps use services that people not even aware of that to do background processing as closing activity stop main execution of application, it's actions dont need to be visible to user.
    01-16-2013 11:02 PM
  12. DroidXcon's Avatar
    I use netflix for hours at a time and maybe runs up 18% .14% without opening sound seriously unlikely from backgroun running
    01-16-2013 11:48 PM
  13. EvilMonkey's Avatar
    If it's using the battery and you haven't even opened it, something is goofy. Uninstall it and reinstall it.
    But no....it shouldn't be using any battery if you're not using it.
    01-17-2013 09:24 AM
  14. carracerz14's Avatar
    If you don't use it, then just uninstall it??? Problem solved.
    Sent from my RAZR MAXXIMUS
    02-03-2013 11:24 PM
  15. quicksilver53's Avatar
    I have been using Netflix on my Android devices for 2 year and never had the problem you described OP. As someone suggested I would uninstall a d reinstall the app.
    Sent from my HTC One X using Android Central Forums
    DroidXcon likes this.
    02-04-2013 03:10 AM
  16. rhubarb314's Avatar
    I'm seeing the same thing, but for me it's 9%. Just in the last week.
    02-06-2013 05:28 PM
  1. Replies: 1
    Last Post: 11-24-2012, 02:36 PM
  2. does sms popup use a lot of battery?
    By ahawkua in forum General Help and How To
    Last Post: 11-23-2012, 08:05 PM
  3. Is the OS supposed to be using a lot of battery life?
    By 2010BmwM3 in forum Verizon Galaxy Nexus
    Last Post: 12-21-2011, 04:30 PM
  4. Powering my TB off an on uses a LOT of battery
    By MojaveHigh in forum Verizon HTC Thunderbolt
    Last Post: 04-22-2011, 07:54 AM
  5. Cell Standby and Phone Idle using a lot of battery
    By splmonster in forum HTC EVO 4G
    Last Post: 06-13-2010, 02:33 PM
