Note 2 video player options stuck on "always"
I have 3 video apps on my note 2. When I go to open a video in my camera I always get to pick which app I want and whether to use it "just this once" or "always". Accidentally clicked "always" and now all videos from camera open with the video trim app. How do I undo the "always" so I can use the other player apps
Re: Note 2 video player options stuck on "always"
Have you tried clearing the App Data altogether or tapping "Clear Defaults"
Clear Defaults is what you have to do. Find the app in Settings/Apps, select it, and tap the Clear Defaults button. If it's a system app, make sure you look under All Apps, not just the Downloaded list.
Lanhoj deserves credit, too! :)
Sent from my DROID RAZR using Android Central Forums
