Results 1 to 5 of 5
    gothe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default No sound
    Hi! I hope someone can help me out with this. Every now and then I lose all sound on my Droid 4 (notifications, YouTube, radio, you name it) and it seems the only way to remedy this is to do a reboot. Does anyone know what the trouble could be, or how I can fix it without rebooting? Much obliged.
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock/Stock/CM9
    Default Re: No sound
    What happens if you put the phone in silent, then turn the volume back on?
    Install any suspect apps lately?
    Worst case, can always try a factory reset.
    Sent from my DROID X2 using Android Central Forums
    gothe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Devinator View Post
    I tried the volume, didn't help. You're right, I'll have to check my apps and maybe do a factory reset. Thanks!
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock/Stock/CM9
    No problem. Before doing the reset, wait to see if anyone else has any ideas, ya know?
  5. #5
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    I wonder if this is similar to the sound issue with the Razr and Razr Maxx (also Motorola), which has been discussed many times on these forums. I periodically lose sound on my Maxx, which typically comes back if I go to the ringtones and play one as a test. Kind of annoying, especially since it sometimes causes me to miss a call. Keeping fingers crossed that this bug will be fixed if and when we get the official Jellybean update.
    So the next time your sound cuts out, try going to Settings/Sound/Phone ringtone, then select any of them to see if it'll "wake up" your sound.
  1. No sound with videos???
    By rosariorose9 in forum Verizon Droid Incredible
    Last Post: 06-15-2010, 12:25 AM
  2. Dial Pad no Sounds.
    By jmillernyc in forum Verizon Droid Incredible
    Last Post: 05-31-2010, 10:01 AM
  3. My alarm has no sound
    By Jesse@AirLift in forum HTC Droid Eris
    Last Post: 03-03-2010, 12:50 AM
  4. Help no sound
    By joe_5962 in forum HTC Droid Eris
    Last Post: 02-22-2010, 07:37 PM
  5. Video has no sound
    By zeravla531 in forum HTC Hero
    Last Post: 01-07-2010, 08:56 PM
