Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Devinator
    linksfiend's Avatar
    Posts
    Global Posts
    6 Global Posts
    Default Changing the browser that launches
    In Froyo, how do I change which browser and page lauches when I hit the little grey globe at the bottom/center of the screen?
    It used to launch the Dolphin Browser "speed dial" but somehow got reset to the stock browser.
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: Changing the browser that launches
    Is it the wrong icon? Or is an action defaulted to the wrong browser? If it's a default issue you can try clearing defaults for the stock browser in manage apps. Then when you try the action again, it should prompt you to select a browser and you can pick dolphin and set it to default.
    Sent from my DROID X2 using Android Central Forums
    Thanked by:
    linksfiend likes this.
    linksfiend's Avatar
    Posts
    Global Posts
    6 Global Posts
    Quote Originally Posted by Devinator View Post
    That's exactly what I needed to do. Thanks Dev. I tried going to "manage applications" → "all" →"Browser" before, but I just hit "Clear cache" and "Clear data". I never noticed to scroll down and hit "Clear defaults".
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    You betcha, glad I could help.
  1. Replies: 5
    Last Post: 08-12-2011, 10:28 AM
  2. How to specify / change the browser
    By Myronbg in forum Acer Iconia A500
    Last Post: 05-27-2011, 12:40 AM
  3. Phones that changed the industry?
    By tony bag o donuts in forum The Android Central Lounge
    Last Post: 08-23-2010, 08:43 PM
  4. Replies: 6
    Last Post: 07-31-2010, 08:56 PM
  5. Replies: 8
    Last Post: 06-15-2010, 09:50 PM
