1. havetolovemusic's Avatar
    So I have the dx. I can connect to wifi perfectly fine. However when I turn off my wifi, then I turn it back on I have to go back into the settings, wifi settings, and then my wifi will connect to my network. Even if I don't move my position, I still need to go into that settings page before the wifi will connect. I don't have to select anything for it to connect, all I have to do is just go to the settings page and then it will connect. Is this just how it is or is there something wrong here? Thanks in advance for the help!
    07-23-2010 01:32 PM
  2. troffe's Avatar
    I'm not sure if that's how it is or not.
    My nexus one automatically connects 95% of the time, as long as the location is "remembered".
    Your phone might be different.
    07-24-2010 02:43 PM
  3. takoeeje's Avatar
    My HTC inspire does the same thing: will not auto connect to remembered networks. All I have to do is go to the Settings - Wireless & Networks and then it will auto connect once I am on that page. Annoying!
    Does anyone know a fix?
    06-25-2011 10:00 AM
  4. Moscow Desire's Avatar
    Welcome to android.
    Usually, if your wifi remembers a connection, it will connect the next time it encounters that specific connection.
    But, what happens if you have more than 1 connection available???
    This is why, you have to go into the connection settings, and actually connect it.
    Usually, you can do this from the drop down, when it finds new connections.
    06-27-2011 06:09 AM
