Results 1 to 4 of 4
    Default Samsung Note Saving to SD card
    I have a Samsung Note 10.1 and have just purchased an micro sd card to suit. What i want to do is save my downloaded films to the card for when i go on holiday. my question is how do i do it, that is if it can be done, any help would be much appreciated. Thanks Duncan
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Carrier
    Stock/Stock/CM9
    Default Re: Samsung Note Saving to SD card
    Where are the movies?
    Sent from my DROID X2 using Android Central Forums
    Have down loaded from my flixster account
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Carrier
    Stock/Stock/CM9
    If that is streaming it won't work. If you have the actual file on a computer it's just a matter of moving it over to your phone VIA USB.
  1. can texts be saved to sd card
    By blunt420 in forum Verizon Droid Incredible
    Last Post: 07-10-2013, 05:39 AM
  2. doubleTwist not saving to SD Card
    By jharo in forum Android Apps
    Last Post: 01-19-2011, 12:25 PM
  3. What's best app to explore and save to SD Card and built in phone storage ?
    By jasonvancouver in forum Verizon Droid Incredible
    Last Post: 07-02-2010, 09:33 PM
  4. how to delete pictures saved to sd card ??
    By thatguy in forum General Help and How To
    Last Post: 01-10-2010, 02:37 PM
  5. how to delete pictures saved to sd card ??
    By thatguy in forum HTC Droid Eris
    Last Post: 01-10-2010, 02:07 PM
