Results 1 to 3 of 3
    Question Trouble sending mass Text Messages
    I'm a youth pastor, and I communicate with my students largely by text. The stock messaging app on my GNex doesn't allow for texting to contact groups. So I downloaded Go SMS Pro, which does. Problem is, when it gets around recipient 20, it gives me the message in the picture here.
    This notification pops up for every subsequent message until the whole process is done (which means that I've got to sit by my phone and click "Allow" about 40 times.
    So, why does it do this? Based on the holo theme of the notification, I would say it's a system notification and isn't produced by the GO SMS Pro app itself. Has anyone else encountered this? Is there a way to turn this notification off?
  2. #2
    Default Re: Trouble sending mass Text Messages
    I was actually just looking at this app for the same thing. Guess I will wait and see what the verdict is.
    Sent from my DROID RAZR HD using Android Central Forums
  3. #3
    You can send 100 per hour, per app before this is called. It's hard-coded into the source, but if you're rooted it's fairly easy to fix.
    Code:
    sqlite3 /data/data/com.android.providers.settings/databases/settings.db
    sqlite> INSERT INTO gservices (name, value) VALUES
    ('sms_outgoing_check_interval_ms', 0);
    will shut it off, but you do need to be root and have the sqlite3 binary in your path.
    from jerry This prompt made me furious
    also read the thread
  1. Thunderbolt is sending invisible text messages!
    By potatolover1102 in forum Verizon HTC Thunderbolt
    Last Post: 03-24-2011, 06:04 PM
  2. On cm 6.1.2 i always lose signal when sending a text message. Why?
    By Jason Black in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-03-2011, 06:24 AM
  3. New Captivate not sending/receiving Text messages
    By Phazuka in forum AT&T Captivate
    Last Post: 10-18-2010, 04:39 PM
  4. Mass text messaging
    By Rderosier86 in forum Sprint Epic 4G
    Last Post: 09-13-2010, 01:01 PM
  5. Is anyone else having trouble sending/receiving texts with addresses
    By SeizedPropaganda in forum Verizon Droid Incredible
    Last Post: 06-16-2010, 06:30 PM
