Results 1 to 2 of 2
    socko3161's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default help printing from App
    I have the coupons.com app on my sg3 and was wondering if there was a way to print from my phone from within the App to my hp printer... I keep getting an error that I can only print wirelessly from a samsung printer... my iphone would print the coupons I wanted instantly through wifi... is there a way around this samsung only printer crap my phone displays???
  2. #2
    Strider2112's Avatar
    Posts
    Global Posts
    229 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help printing from App
    Maybe someone will correct me if I'm wrong, but the print from anything feature only works if you:
    a) Install software specifically designed for your printer, to work over wifi or even the internet
    or
    b) Install software specifically designed to be able to print over wifi to a printer connected to a router.
    I know I played around a little bit with this, not with the coupon app, and used the app PrintBot with some success with a couple different printers.
    Once again, I can't say for sure whether the mechanics are the same for the coupon app...
  1. Print Directly from App Using HP ePrint and CloudPrint
    By gldnbear in forum Acer Iconia A500
    Last Post: 05-03-2012, 08:27 PM
  2. how do i print from my gnex over wifi or do i need a app?
    By bobgilbert11 in forum Verizon Galaxy Nexus
    Last Post: 01-13-2012, 05:16 PM
  3. need help buying from apps lib with my coby 7024
    By drweisz in forum Introductions
    Last Post: 07-29-2011, 05:59 PM
  4. Replies: 3
    Last Post: 03-29-2010, 11:15 PM
  5. Need Help with Facebook App
    By olson0827#AC in forum Android Apps
    Last Post: 11-11-2009, 10:25 PM
