1. beercan21's Avatar
    What do I have to do to get PlayerPro recognized as a music player app? When I say "listen to <artist>" using the Google voice search app, it gives me a "Complete action using" list that includes iHeartRadio, Pandora, Google Play Music, Slacker Radio, and YouTube, but no PlayerPro option. What's the trick? I'd really like to set it as the default music player.
    Using Android 4.0.4.
    01-23-2013 10:10 PM
  2. Shadowriver's Avatar
    Means PlayerPro is not define it self to support intent triggered by voice command. You can try to hack it and add intent filter entry in playerpro manifest file so call can be sent to app and prey that app code can handle intent arguments if you got root. Or simply... send email to develoer to fix it
    beercan21 likes this.
    01-24-2013 01:58 PM
  1. How to set image as a wallpaper on a single home screen
    By Jalpa Bhaliya in forum General Help and How To
    Last Post: 11-01-2012, 07:50 AM
  2. how to set my gmail as the default sending account
    By spatterfree in forum Motorola Droid
    Last Post: 09-26-2011, 10:23 AM
  3. How to set up a home-screen as default in T-mobile Tab?
    By subhradyuti in forum Samsung Galaxy Tab
    Last Post: 02-02-2011, 02:50 PM
  4. How to set photo as wallpaper - not just long press
    By allyn274 in forum General Help and How To
    Last Post: 10-21-2010, 11:03 AM
  5. How do i change the default music player?
    By tempest111 in forum HTC EVO 4G
    Last Post: 06-20-2010, 08:23 PM
