rommanager not letting me select option
i installed rommanager on my galaxy s3 (cricket) backed up stock rom before this did nandroid backup and titanium backup installed dre beats from playstore everything was good until it was going to reboot then it froze went into recovery and tried to restore but every time i toggle up and down it keeps skipping so it wont let me click on backup and restore because it keeps skipping please help
Re: rommanager not letting me select option
Sounds to me like another example of where ROM Manager fails.
My best suggestion is to boot into your custom recovery manually and perform all your backup/restores and ROM flashings that way. ROM Manager always seems to blow the deal when it counts the most.
so do i go to mounts and storage because when i toggle up and down it only lets me go to mounts and storage,reboot system now,install from sideload,and wipe cache partition
I'm not familiar with the S3 but there does seem to be some sort of recovery issue going on since its not allowing you to select the option.
Have you tried reinstalling the recovery other than using Rom Manager?
