Results 1 to 3 of 3
    Default How to record audio via bluetooth headset not phone microphone
    I have a Galaxy Note 2 and can't figure out how to record via my bluetooth headset not via the phone mic. Tried 20+ apps that record great via the phone mic but not via my headset.
    Any ideas?
    Thanks.
  2. #2
    lynnneil's Avatar
    Posts
    Global Posts
    99 Global Posts
    Default Re: How to record audio via bluetooth headset not phone microphone
    You can record audio with a simple app called "Bluetooth Audio Recording".
  3. #3
    Most Androids have a problem with BT microphone routing. This issue has been discusssed on many forums and there is no simple solution. My xperia Z , for example, will only communicate with "Voice Dialer" when using any BT microphone. There appears to be no easy way to route the audio from the BT mic to the application of my choice.
    You might want to try an application called "Bluetooth Launch". This works on some Androids , but not on the xperia Z. If you find a solution which works let me know and I will be forever in your debt !
  1. Replies: 15
    Last Post: 04-26-2013, 04:39 AM
  2. Replies: 3
    Last Post: 11-28-2012, 02:10 PM
  3. Replies: 2
    Last Post: 10-10-2012, 08:45 PM
  4. Stream audio from my phone to my PC via Bluetooth. Is it possible
    By britheguy12 in forum Virgin Mobile Optimus V
    Last Post: 08-06-2012, 10:49 PM
  5. I would LOVE to listen to music via bluetooth headset
    By txphonejunkie in forum General Help and How To
    Last Post: 06-04-2011, 10:38 AM
