- 01-25-2013, 07:43 AM
Thread Author #1
Samsung GTI 9070 connection troubles.
Hi guys, just bought a new Samsung Galaxy S Advance (GTI 9070) and I have a little problem. The data network mode activates itself automatically, at any time. When the WiFi connection is on, it automatically stops when entering the Play Store. When I enter on instragram, facebook or any other programs with the data network mode activated, it turns itself off. I have android v 2.3.6..
How can I fix this ? - 01-27-2013, 04:49 PM
Thread Author #2
- 01-28-2013, 06:32 AM #3
Re: Samsung GTI 9070 connection troubles.
I'm confused. What's the problem? Data is turning itself off or Wi-Fi is?
Sent from my DROID X2 using Android Central Forums
- 02-01-2013, 09:38 AM
Thread Author #4
Both of them, on and off.
For example, if I have the wifi connection enabled and I try to watch a video on youtube, when I press the play button, it turns off. As I exit youtube, it turns itself on.
Another example... When I leave the phone on the desk, with the data network mode deactivated, after a few minutes, I start getting facebook notifications and then I see that the data network mode activated. - 02-01-2013, 12:58 PM #5
You said it's new, so, if you factory reset and it doesn't fix the problem, send it back and get it replaced.
- 03-13-2013, 03:43 PM
Thread Author #6
- 03-14-2013, 07:34 AM #7
- 03-14-2013, 02:09 PM
Thread Author #8
Well, after a few months of using it, it's not conveniently for me to reset it. Either I solve it somehow without reseting it, either I do nothing about that.
Now, when I access Google Play / try to watch anything on youtube / try to log in on zynga poker on Wi-Fi, it turns off. - 03-15-2013, 07:24 PM #9
- 03-16-2013, 01:42 PM
Thread Author #10
Bionic Wi-Fi Connection Troubles
By VickiF in forum Droid BionicReplies: 9Last Post: 11-12-2011, 01:02 PM -
Samsung Galaxy S2 connected to USB mouse, and it works!
By bwonghk in forum Sprint Galaxy S II Epic 4G TouchReplies: 5Last Post: 07-28-2011, 12:23 PM -
internet connection trouble
By weasel123 in forum Verizon HTC ThunderboltReplies: 3Last Post: 04-06-2011, 04:27 AM -
Samsung Fascinate wont connect to Belkin router
By Jeffrow in forum General Help and How ToReplies: 9Last Post: 12-29-2010, 04:37 PM
Reply
