Results 1 to 16 of 16
    Default Galaxy S3 - Screen timeout and menu key problem
    Hi all,
    I've searched around but wasn't able to find an answer anywhere.
    My issue is simple. My screen would timeout, but not lock, while I was using it. So the intuitive thing to do is to hit the menu key to turn the screen back on, and thats what I do. The problem is that the screen would turn back on, but as soon as its on it would also go straight to the menu (as if the screen hasn't timedout at all), which forces me to re-enter the app again. As this happens every 30 seconds or so, this is quite annoying.
    Needless to say, the stayawake feature doesn't always work well. I could obviously set the screen timeout for longer than 30 seconds, but this would just drain the battery.
    Anyone else experienced this issue? Can you help me fix this (so when I hit the menu key, it would only turn the screen back on, without going to the menu)?
    Thanks a lot!
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: Galaxy S3 - Screen timeout and menu key problem
    Why don't you just hit the power button to turn the screen back on?
    Sent from my DROID X2 using Android Central Forums
    Tried it, it locks the screen. The volume keys don't work either.
    Any suggestions how I can fix thix?
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    The screen is off and the power button locks the screen instead of just turning it back on?
    What app are you using that you need the screen to stay active?
  5. #5
    Im facing the same problem and it is getting very disturbing.
    Default
    Quote Originally Posted by Devinator View Post
    Any app, really. The browsers, the messaging, games, everything.
    Anyway to get around it? Is it some settings thing I'm
    missing?
  7. #7
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Well, if you are actively using it, it shouldn't time out like that. The only thing I could see happening is if you were doing something where you aren't interacting with it (like watching a movie) and it timed out. But, you are saying it's happening while you are browsing or playing a game?
  8. Thread Author  Thread Author    #8
    Default
    Yeah, pretty much any activity. Wherever I'm in, the screen will turn on after hitting the menu key, and then send me straight to the menu- which will require me to locate the app I was in and go back there again.
    What happens to you when your screen goes off(not goes dimmer, but total black) and you press the menu key? Do you get sent to the menu or does your screen only turns on (without leaving the app you're in)?
  9. #9
    Default Odp: Galaxy S3 - Screen timeout and menu key problem
    It might be background service doing, check the list of active services in application settings and kill any that looks susspicus
  10. #10
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Quote Originally Posted by a1745 View Post
    My menu key doesn't wake up my phone. My Home key does though. But, it behaves exactly as my power button does. Just turns the screen on and brings me to the lock screen. When I unlock my phone, it goes right back into the app I am in.
  11. #11
    I finally got the solution for this problem.
    Go to your phone settings > Language and input > Voice search. Make sure here " Open via home key " option is selected. There you go! Hope it helps. =)
  12. #12
    I think ever since 4.1 ive been having the same problem. You used to have five seconds after the screen timed out to press the home button and resume what you were doing without going to the lock screen. Now, pressing the home button too soon after the screen blacks out will turn the screen back on but also send you "home" which is very annoying :/ I'm hoping this re-articulation of the problem might help find us a fix from someone.
  13. Thread Author  Thread Author    #13
    Default
    Quote Originally Posted by Android Lover s3 View Post
    Hi there, I don't have this option in mu voice search menu. Strange that this solution comes from this menu setting.
    Thanks anyway!
  14. Thread Author  Thread Author    #14
    Default
    Quote Originally Posted by Valid User Name View Post
    I know, its really annoying! I guess it makes it worse that our phones didn't have this issue a few months/weeks ago. hopefully they get this sorted, hitting the home key is the most intuitive thing to do when your screen goes black and you want to turn it back on.
  15. #15
    I'm having the same issue. Very upsetting. I've tried every setting option I can think of, too. Maybe I'll just end up emailing Samsung. I love my Gs3 but this problem is annoying!
  16. #16
    Download the free app Caffeine - keeps screen lit
  1. Best Galaxy S3 Screen Protector - Customization the Key
    By DelbertKim in forum Samsung Galaxy S3 Accessories
    Last Post: 03-28-2013, 05:22 PM
  2. US Galaxy S3 Screen Color Profile removed?
    By junglejunkie in forum Samsung Galaxy S3
    Last Post: 06-28-2012, 01:34 PM
  3. prblems with my galaxy s3 screen!!
    By ivo39 in forum Samsung Galaxy S3
    Last Post: 06-22-2012, 01:01 PM
  4. Screen timeout and brightness adjustable?
    By charles2859 in forum LG myTouch
    Last Post: 02-02-2012, 02:49 PM
  5. Screen timeout and poor touch recognition...
    By dreamliner in forum Sprint Photon
    Last Post: 11-06-2011, 06:29 AM
