Results 1 to 4 of 4
    DarcMobile's Avatar
    Posts
    Global Posts
    50 Global Posts
    Default Recommended Mid-range phone with above-average battery?
    Hi I'm looking for mid-range Android phone for my friends
    Here are specs that I care about:
    - Above average battery life
    - At least ICS 4.0.3
    - At least 4" Screen
    I'm considering Galaxy S2, does it has great battery?
    I can't really calculate it based on mAh alone because my Galaxy Nexus battery sucks compared to others with same mAh.
    Any other suggestion?
    Thanks
  2. #2
    Default Re: Recommended Mid-range phone with above-average battery?
    One of the devices that you may want to take a look at is the Samsung Galaxy S3 Mini.
    It's a scaled down version of the S3, but looks to be a pretty good device that satisfies the criteria in your post.
    I'd say that if you were already at the S2, then the S3 Mini should make it into your consideration set.
    Best of luck.
    Sent from my SGH-I317M using Tapatalk 2
    DarcMobile's Avatar
    Posts
    Global Posts
    50 Global Posts
    Quote Originally Posted by juanpanlilio View Post
    Best of luck.
    Thanks for the reply, but S3 Mini has lower battery mAh but with same resolution as S2.
    Does that makes S3 Mini last shorter than S2?
  4. #4
    whats your budget? have you looked at Nexus 4?
  1. Can't wait to get a new phone with a good battery ... just venting
    By skatergirl in forum Verizon HTC Rezound
    Last Post: 01-27-2013, 09:14 AM
  2. Nice MId-range phone.
    By Takenover83 in forum Misc. Android Phone Chat
    Last Post: 12-02-2012, 11:02 AM
  3. How to reboot phone with non-removeable battery?
    By twalkbox in forum General Help and How To
    Last Post: 03-11-2012, 11:36 AM
  4. The perfect mid-range phone?
    By Kevin O'Quinn in forum Other Sony Android Phones
    Last Post: 11-20-2011, 11:48 PM
  5. Custom DIY Dock for phones with cases or extended batteries
    By Jonagpa in forum Fascinate Accessories
    Last Post: 04-01-2011, 03:45 AM
