Results 1 to 6 of 6
- 01-27-2013, 07:34 PM
Thread Author #1
A-link pad7 help
Hello to all member and guests . i really need help with this pad7 A-LINK PAD7 is just PAD7 with no + . so there is nothing in google about this pad i need if someone have this same pad backuped rom for this pad please. let me know and post. cuz i have install MID7022 coby kyros firmware but camera not working is not same.
Thanks - 01-28-2013, 06:36 AM #2
Re: A-link pad7 help
So you want the stock ROM for it? What happened?
Sent from my DROID X2 using Android Central Forums
Thanked by: - 01-28-2013, 08:11 AM
Thread Author #3
Yes bro i want stock ROM which come with pad7 ,mm there problem with software . and i was want to upgrade but idid not search before upgrade to save stock backup. then looking around i found this MID7022 but its not same with A Link pad7 both have some design but are different. install 4.0 android not wok. and with this mid7022 2.3.3 android i install but to much bugs and not working properly
thankss - 01-28-2013, 12:40 PM #4
Can you get the stock ROM from the manufacturer? Or did you try Googling for it/checking AC for it?
- 01-28-2013, 01:42 PM
Thread Author #5
- 01-29-2013, 06:26 AM #6
If you can find a phone number for the manufacturer, you'll have more luck.
Phone Tablet link up help
By odd1ne in forum Tablet ChatReplies: 0Last Post: 07-24-2012, 11:42 AM -
Contacts, sync, link - please help...
By radtech in forum AT&T Inspire 4GReplies: 4Last Post: 06-11-2011, 08:36 AM -
help with linking contacts
By xchellemariex in forum Verizon HTC ThunderboltReplies: 22Last Post: 03-26-2011, 06:17 PM -
Help find a link
By EricP2631 in forum HTC EVO 4GReplies: 0Last Post: 09-03-2010, 07:00 PM -
Help with web link - Is it a problem with phone?
By totaled in forum HTC EVO 4GReplies: 7Last Post: 06-22-2010, 09:57 AM
Reply
