App or Widget or Shortcut to Lock the Screen
Hi All,
Thanks in advance for helping me out. I'm looking for an app or widget or shortcut or something that will force the phone to lock. Right now the phone locks after 10 minutes. However, if a situation arises where I need to lock the phone immediately there's no option to do that. There is an option under Settings to trigger on power button push. I'm not a huge fan of that since I use the power button to switch off the phone when I don't need it (to save battery). If nothing exists I might try the power button option.
I have a Verizon Motorola Droid Bionic with Android version 4.0.4.
Thanks!!
Re: App or Widget or Shortcut to Lock the Screen
Try [Only registered and activated users can see links. Click Here To Register...], one of my favorite apps ever. It has a Screen Lock toggle option which works pretty well (although on my Razr Maxx, there is a 1-2 second pause between tapping the toggle and when the screen actually locks). Besides that, it's also a very powerful and versatile toggle bar.
OP said he'd prefer not to use the power button if he doesn't have to.
I use Nova Launcher Prime & WidgetLocker.
Then I assign a gesture to lock my phone.
Thanks everyone for your comments!!! Power Toggles did the trick. Thanks again, to everyone!
