DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Results 1 to 5 of 5
    Default Text Messages disappearing
    Sorry if this has already been asked. I started using an app that came pre-installed called At&t messages a couple days ago. I found I did not like it so I deleted and canceled the service. Since then my contacts have gone completely crazy. The names are being switched and merged with others along with phone numbers, they are being put with contacts that they do not belong too.I deleted all my contacts to start over and my phone would add them again on its own. I think I fixed that by going online and deleting and re-adding all my contacts on Att address book website. However now my text messages are disappearing. I will be texting someone and the whole conversation will just disappear and only the last couple of recent texts will show. What is going on? How do I fix this? Thank you!
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: Text Messages disappearing
    You don't keep your contacts synced to Google?
    Can you clear cache on contacts?
    Sent from my DROID X2 using Android Central Forums
    Quote Originally Posted by Devinator View Post
    No I do not sync contacts with Google, I actually do not know how to do that. I have them synced with att address book where I can go online and add or delete or edit them. I thought I had the contacts problem solved but today I noticed the numbers are getting mixed up again.
    How do I clear cache???? Thank you!
  4. #4
    Default Odp: Text Messages disappearing
    Quote Originally Posted by boymom05 View Post
    You should have in synchronisation options in setting. Try to disable current sync service there, rebuild your contacts somehow and then you can sync it with google if you want. You might also have some conflicting syncing there, check if you have only one of such services turned on.
    I dont think clearing cache will help in anything (do contacts cache anything to begin with?) and clearing data will only clear contacts... but who know it might work, your contacts are mess anyway right?
  5. #5
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    I don't think they do, but I didn't want to suggest clearing data just yet.
    To have your contacts save to Google, go into Contacts and then Settings. You can set it in there.
  1. Disappearing text messages
    By pcbtmr in forum Verizon HTC Thunderbolt
    Last Post: 05-18-2011, 10:27 AM
  2. All my text messages disappeared....
    By MannyZ28 in forum HTC EVO 4G
    Last Post: 04-26-2011, 11:20 AM
  3. text messages are not appearing in order
    By charisma in forum T-Mobile G1
    Last Post: 01-24-2010, 09:50 AM
  4. Text messaging problem with wifi on
    By Anubis in forum HTC Hero
    Last Post: 10-23-2009, 04:18 PM
  5. Sprint Hero has text messaging problem!
    By maxfire05#ac in forum HTC Hero
    Last Post: 10-10-2009, 10:49 AM
