Results 1 to 7 of 7
    Default USB Not Working
    Hi all, I have a Samsung Galaxy Young and when I plug it in to my Laptop or PS3 it would come up with the little USB symbol, but now when I do, it just charges, my phone wont reconise my laptop or PS3 and more, and they don't reconise my phone. Whats going on?
    Sent from my GT-S5360 using Android Central Forums
    Android!!!
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: USB Not Working
    What USB mode is your phone in? When you plug it into your laptop, go to Manage USB in your notifications. Is it set to charge only?
    Thats what I meam, it USED 2 come up, but now it doesn't. I don't know why.
    Android!!!
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    You mean you don't get the notification that it's plugged in?
    If so, try a different cable. If multiple cables don't work, there might be something wrong with the port on the phone. And since you are trying it on multiple devices, but it's not working, it's either the cable or the phone I would think. If a different cable doesn't work, I'm not sure. Maybe a factory reset would need to be done, but, hopefully someone else will chime in with some advice before you have to go that far.
    Quote Originally Posted by Devinator View Post
    Kk, when I get home I will get a diff cable.
    Android!!!
    Thanks, the other cable works
    Android!!!
  7. #7
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    No problem. Glad that fixed it.
    Sent from my DROID X2 using Android Central Forums
  1. Phone not charging and USB not working
    By thkerotera in forum AT&T Samsung Infuse
    Last Post: 05-28-2012, 04:27 AM
  2. Replies: 29
    Last Post: 04-12-2012, 06:23 PM
  3. USB not working on multiple PC's.
    By androidcore in forum Droid RAZR
    Last Post: 03-13-2012, 07:14 PM
  4. USB not working, 2.3.5 won't install
    By chefkeyser in forum Sprint Nexus S 4G
    Last Post: 08-02-2011, 07:41 AM
  5. USB Tethering with EVO and Froyo not working
    By drudawg in forum HTC EVO 4G
    Last Post: 08-04-2010, 08:56 AM
