1. hamr1's Avatar
    Trying to figure out this OTA updating. It seems to me that with BB all your updates come thru BB desktop manager. I read a few days ago an update is available for my SG2. Looking into it further and based on the baseband version on my phone my update would be arriving OTA only. Now some versions you can update manually or in some cases wait for the OTA. It also says it could be anytime within a 2week period. How is this stuff determined, by your location? I like to understand how stuff works. Anyone have any idea? Thanks, ok so maybe I can be alittle impatient
    01-30-2013 09:32 AM
  2. Mooncatt's Avatar
    OTA updates generally come on their own when your phone is selected to be sent it. Carriers send the updates out in batches, so even trying to manually update during the roll it period won't work if your phone isn't in the current batch. You should get a notice on your phone when it is able to update.
    As for when it's determined what phones are updated, I personally think it is by ESNs or something like that. Some people think it's by location, but after watching update threads, I'm pretty sure that isn't the case.
    hamr1 likes this.
    01-30-2013 12:08 PM
  3. still1's Avatar
    Its up to the manufacturer. Samsung has Kies which let you update phone via desktop. They do it mostly for testing before they do OTA(over the air)
    what time it comes is still a mystery with Android.
    hamr1 likes this.
    01-30-2013 12:50 PM
  4. Paul627g's Avatar
    Like to add just if your device is currently rooted there is a good chance that any OTA update or manual desktop aided update could fail upon install. Some cases they will go thru if situations are just right with the device on things not being altered but in most cases if your rooted and plan on grabbing the official OTA then you need to consider either returning back to factory stock/unrooted or wait for your favorite custom ROM developers to apply the new update to their work.
    hamr1 likes this.
    01-30-2013 01:10 PM
  1. How does Outlook work with Android Os?
    By polar135 in forum Motorola Droid
    Last Post: 11-01-2010, 10:59 AM
  2. Unrevoked 3.21 Simple root is out how does it work?
    By clavodulce16 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 09-20-2010, 09:03 AM
  3. Replies: 2
    Last Post: 09-19-2010, 08:11 PM
  4. How does support work with Best Buy?
    By Josh K in forum HTC EVO 4G
    Last Post: 05-14-2010, 05:28 AM
  5. How does WiFi work?
    By JFeisty in forum General Help and How To
    Last Post: 11-14-2009, 07:31 PM
