1. damo's Avatar
    Can anyone shed any light on this?
    When I play music or podcasts in the car on any of my phones and plug a cable from the headphone socket to my car aux socket and charge the phone at the same time, I hear interference through the car speakers. I was using a cheap car charger, so I changed it for a genuine HTC one, and the same thing happens. This happens on both my Nexus 4 and my GS3. As soon as I unplug the car charger, the noise goes away.
    Is this normal, can it be cured?
    Thanks folks!
    01-31-2013 03:46 AM
  2. Devinator's Avatar
    Does the static happen when playing a song? I hear weird static noises when I have my phone plugged in, but it goes away as soon as I play a song.
    Sent from my DROID X2 using Android Central Forums
    01-31-2013 07:11 AM
  3. Mooncatt's Avatar
    It has to do with noise in the car's electrical system and is very common, especially on low end stereos. The way I've fixed it was with a new stereo that ended up having a noise filter built into the power line (was replaced because I just didn't like the stock head unit, but discovered this). I'm not sure exactly what causes the noise and how it is transferred, but I suggest looking around car audio forums or talk to some install shops. You may be able to get a noise filter aftermarket for your current stereo.
    damo likes this.
    02-01-2013 02:07 AM
  1. Can't play music and record video
    By Aquila76 in forum Verizon HTC Thunderbolt
    Last Post: 11-17-2011, 12:27 AM
  2. GPS fails when playing music, GPS signal drops
    By Mark Butler in forum General Help and How To
    Last Post: 10-22-2011, 01:30 AM
  3. Replies: 8
    Last Post: 08-11-2011, 01:03 PM
  4. Aux/headphone port skipping when playing music?
    By lolfests in forum Verizon Fascinate
    Last Post: 02-10-2011, 08:24 PM
  5. High Pitching Whirring Sound When Using Headphones and Charging
    By Saiyaman156 in forum General Help and How To
    Last Post: 07-23-2010, 12:54 PM
