1. Saige Leslie's Avatar
    I've been struggling with wifi on my Droid Pro for a while now. I tried Wifi Fixer, forgetting networks, even resetting to factory. When I try to connect to an open network, it says obtaining up, remembered, connecting, then disabled. When I connect to closed networks, it works for a while thence wifi becomes ed and goes off and on over and over. Sometimes turning my phone off and on again helps. Most times it doesn't. HELP!
    01-31-2013 08:19 AM
  2. Devinator's Avatar
    So you have tried several networks and a factory reset didn't work? I would think it was a hardware issue. Are you under warranty?
    Sent from my DROID X2 using Android Central Forums
    01-31-2013 11:14 AM
  3. Saige Leslie's Avatar
    I'd have to check.
    01-31-2013 11:32 AM
  4. Devinator's Avatar
    If you are, get it replaced.
    01-31-2013 03:22 PM
  1. HP Touchpad/Android won't connect to Wifi
    By ZTharakan in forum HP Touchpad
    Last Post: 12-30-2013, 05:46 AM
  2. Won't connect to wifi?
    By KyleB4real in forum HTC EVO 4G LTE
    Last Post: 11-10-2013, 06:16 PM
  3. My phone won't connect to wifi... [IMPORTANT]
    By Perseveranze in forum General Help and How To
    Last Post: 11-08-2012, 09:03 AM
  4. My phone won't connect to wifi... [IMPORTANT]
    By Perseveranze in forum Samsung Galaxy S3
    Last Post: 11-07-2012, 04:37 PM
  5. Phone won't connect to wifi or 3g network
    By palmer0700 in forum Samsung Replenish
    Last Post: 04-25-2012, 12:39 PM
