Droid Pro won't connect to wifi
I've been struggling with wifi on my Droid Pro for a while now. I tried Wifi Fixer, forgetting networks, even resetting to factory. When I try to connect to an open network, it says obtaining up, remembered, connecting, then disabled. When I connect to closed networks, it works for a while thence wifi becomes ed and goes off and on over and over. Sometimes turning my phone off and on again helps. Most times it doesn't. HELP!
Re: Droid Pro won't connect to wifi
So you have tried several networks and a factory reset didn't work? I would think it was a hardware issue. Are you under warranty?
Sent from my DROID X2 using Android Central Forums
If you are, get it replaced.
