Results 1 to 4 of 4
- 01-31-2013, 08:19 AM
Thread Author #1
Droid Pro won't connect to wifi
I've been struggling with wifi on my Droid Pro for a while now. I tried Wifi Fixer, forgetting networks, even resetting to factory. When I try to connect to an open network, it says obtaining up, remembered, connecting, then disabled. When I connect to closed networks, it works for a while thence wifi becomes ed and goes off and on over and over. Sometimes turning my phone off and on again helps. Most times it doesn't. HELP!
- 01-31-2013, 11:14 AM #2
Re: Droid Pro won't connect to wifi
So you have tried several networks and a factory reset didn't work? I would think it was a hardware issue. Are you under warranty?
Sent from my DROID X2 using Android Central Forums
- 01-31-2013, 11:32 AM
Thread Author #3
- 01-31-2013, 03:22 PM #4
If you are, get it replaced.
Won't connect to wifi?
By KyleB4real in forum HTC EVO 4G LTEReplies: 10Last Post: 03-24-2013, 09:16 PM -
My phone won't connect to wifi... [IMPORTANT]
By Perseveranze in forum General Help and How ToReplies: 1Last Post: 11-08-2012, 09:03 AM -
By Perseveranze in forum Samsung Galaxy S3Replies: 3Last Post: 11-07-2012, 04:37 PM -
HP Touchpad/Android won't connect to Wifi
By ZTharakan in forum HP TouchpadReplies: 16Last Post: 11-01-2012, 01:02 PM -
Phone won't connect to wifi or 3g network
By palmer0700 in forum Samsung ReplenishReplies: 3Last Post: 04-25-2012, 12:39 PM
Reply
