Hi everyone..
I am having a problem with directory bind app in my galaxy note 2 running CyanogenMod 10.1
I write the directories correctly but its not binding them.. It says that bind is working but its not.. I tried to use many directories which all of them takes you to same place but no luck..
I know its because of CyanogenMod because on touchwiz it was working fine..
so any help to fix that? I love CyanogenMod even if its having many issues and I don't want to go back to touchwiz for that.. I have many apps that are +1 GB each.. I have memory stick 32 GB and internal storage of only 10 (this should actually be 16 -_- )
So anyone has any idea that might fix this?
My device:
Samsung galaxy note 2 GT-7100, Running CyanogenMod,
My device:
