1. phil321's Avatar
    Hi guys
    I'm new to Android and the forum so please be gentle with me. Also apologies if this is the wrong place.
    I am switching from a Blackberry to Android. I have bought a used Samsung Galaxy S 2 to get up and running. The phone is 3 months old. The previous user seems to have taken all his old stuff off but you never know. Should I restore factory settings and do the upgrade to Jelly Bean before I start?
    Thanks
    Phil
    02-01-2013 03:12 AM
  2. B. Diddy's Avatar
    Doing both is a good idea. I'd suggest updating the OS first, then doing a factory reset, which can act to clear out the cobwebs, so to speak.
    Sent from my DROID RAZR using Android Central Forums
    02-01-2013 03:59 AM
  3. still1's Avatar
    I agree with B. Diddy.
    although it wouldnt hurt to factory reset. login without entering your gmail id. update to latest. factory reset again
    02-01-2013 11:04 AM
