Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Shadowriver
    Lightbulb tethering
    how can I use my 2.3.6 ginger bread android as husband modem?
  2. #2
    Default Re: tethering
    Marry it with wife modem (sorry could not stop my self)
    But for real you should have something in connection settings, if oyu don't have it you might have some carrier mutant phone which thedering blocked, then only way to do it is via rooting.
    Devinator likes this.
  3. #3
    srkmagnus's Avatar
    Posts
    ROM
    Calkulin 2.7/Desperado
    If your phone is stock, meaning unrooted and unaltered, then you can't unless the carrier has a plan for you to purchase and activate tethering. Otherwise, you'll need to root the phoned and install a third-party app that enables the tethering feature.
    Check the forum for your device and see what information is available to root the phone model you have.
  4. #4
    Default Odp: tethering
    Quote Originally Posted by srkmagnus View Post
    Kind of not true, I got unlocked stack unaltered sg2 and i have that option, it really depends on where you get phone from
  1. Tethering Apps
    By tyger#ac in forum Android Applications
    Last Post: 04-18-2013, 07:08 PM
  2. Tethering?
    By hroberts89436 in forum HTC Droid Eris
    Last Post: 11-05-2009, 03:34 PM
  3. Tether program
    By ajac in forum HTC Hero
    Last Post: 10-21-2009, 11:54 PM
  4. Tether htc hero with computer via bluetooth?
    By esanger02 in forum HTC Hero
    Last Post: 10-19-2009, 04:30 PM
  5. Replies: 13
    Last Post: 10-07-2009, 02:54 AM
