Results 1 to 4 of 4
- 02-01-2013, 08:57 PM
Thread Author #1
GSM Phone Equivalent to Motorola Photon Q?
Hello,
I'm a bit new to all of this, but am in need of some help. My current phone (T-Mobile G2) is on its last legs, and it's time for me to get a new one. I've played with on-screen keyboards a lot in the past six months, seeing if I can make the transition (I do copious writing on my phone), and right now I'm at a point where I really want a physical keyboard.
Reading around, the Motorola Photon Q is the phone that appeals to me the most - the larger screen, faster processor, and better camera all sell me - but as I understand it, it's a CDMA phone, which means I can't use it on T-Mobile?
Is that actually true, or is there something I could do to use it anyway (I'm no expert on phones, but I can generally follow instructions properly).
If not, is there a viable alternative to the Photon Q (with a physical keyboard) that would work on my T-Mobile network?
Thank you so much for your help! - 02-01-2013, 09:06 PM #2
Re: GSM Phone Equivalent to Motorola Photon Q?
CDMA phones can't be made to work on GSM networks, unfortunately.
Maybe try the Samsung Captivate Glide? You can update it to ICS, at least. Not sure how many QWERTY phones out there have progressed as far as ICS. - 02-01-2013, 09:07 PM #3
- 02-01-2013, 09:13 PM #4
Google's voice transcription has become quite good--is it feasible for you to do a lot of your writing as dictation? A lot of people also swear by SwiftKey, which might make typing with the onscreen keyboard a lot easier.
Moving from HTC EVO 4G to Motorola Photon Q
By cryetter in forum SprintReplies: 5Last Post: 01-08-2013, 01:37 AM -
Why Should I upgrade to a Motorola Photon 4G? (blog review)
By popularbelief420 in forum Sprint PhotonReplies: 0Last Post: 08-08-2011, 09:50 PM -
SD card from my Samsung Epic to Motorola Photon
By piffysb in forum Sprint PhotonReplies: 5Last Post: 08-06-2011, 06:37 AM -
Thoughts on trading to Motorola Photon 4G ?
By jlewis in forum HTC EVO 4GReplies: 7Last Post: 07-13-2011, 09:15 AM -
Best Android GSM phone to date?
By zoltrix in forum The Android Central LoungeReplies: 11Last Post: 06-25-2010, 12:10 AM
Reply
