Results 1 to 10 of 10
    Lightbulb How do I get Wi Fi to start on Boot?
    Hey guys & gals,
    I am looking for a way to get my wifi to start on boot. I hate going to the settings every time especially when some programs start searching for the
    connection automatically. I didn't know if there was a setting or an app to get it going. Thanks!
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: How do I get Wi Fi to start on Boot?
    If you don't want to go into the settings, you can always add a Toggle Widget for Wi-Fi.
    It's not that it's so hard to go into settings to turn on the wifi, I would just like the wifi to start as it is booting.
  4. #4
    I thought that if you have wifi on when you power down, it will be on when you power on again.
    Sent from my DROID RAZR using Android Central Forums
  5. #5
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Quote Originally Posted by B. Diddy View Post
    That's what I thought, just didn't feel like powering down my phone to check.
    Sent from my DROID X2 using Android Central Forums
    This isn't a phone. It's a rooted Nook with CM7
  7. #7
    Shouldn't matter. I think any Android device remembers what state its wifi, Bluetooth, or mobile data (if available) was in when you power it off and then power it back on again. Have you tried it on your Nook?
  8. Thread Author  Thread Author    #8
    yes i have, but when i reboot i have to turn the wifi back on. just figured there was a setting somewhere that i may have accidentally turned off or something to that effect
  9. #9
    Must be something specific to the Nook or to the rooting. I just tested it out on my Razr Maxx and my N7, and both remember if the wifi, Bluetooth, or mobile data were on or off when powered off.
  10. #10
    Quote Originally Posted by djrnewcastle View Post
    sounds like a bug with CM7 on nook. have you tried the latest CM version. might have fixed it.
  1. How do I get my PC to recognize the Nexus as a drive?
    By bbhybridchris in forum Verizon Galaxy Nexus
    Last Post: 12-29-2011, 07:47 PM
  2. How do I get Android Market to update
    By BKVic in forum Verizon Droid Incredible
    Last Post: 06-06-2011, 09:55 AM
  3. How do i get my thunderbolt to sync calendar w/google
    By ORSalesRep in forum General Help and How To
    Last Post: 04-04-2011, 03:24 PM
  4. How do I get the OTA to work?
    By kartoonstew in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 10-01-2010, 08:43 PM
  5. Replies: 5
    Last Post: 01-06-2010, 04:09 PM
