- 02-03-2013, 12:52 PM
Thread Author #1
Google Music Problems
I have two problems: 1. Google play will not allow me to change album art. 2. I no longer have the option to play a play list. I can add it to the queue but not directly play. Any suggestions?
- 02-03-2013, 01:49 PM #2
Re: Google Music Problems
Change album art in the desktop browser version of Google Play Music. It's much easier that way.
Sent from my DROID RAZR using Android Central Forums - 02-03-2013, 03:47 PM
Thread Author #3
- 02-03-2013, 04:49 PM #4
There isn't a need for a "Play" selection, because you can just double tap a track to play it.
I'll see if I encounter the same problem with album art.
Sent from my Nexus 7 using Android Central Forums - 02-03-2013, 05:04 PM #5
- 02-03-2013, 05:21 PM
Thread Author #6
But this IS aproblem if I want to play a playlist when looking at all my playlists. Before, I tapped on the small arrow on the lower right hand corner then tapped "Play." Now double-tapping a playlist does NOT play the list but only opens it. Then I have to double tap on the first song to start the list. Therefore the new method is longer and slower than the old one. Did someone complain about the ability to directly play a song or playlist? Why was this changed? I hate "updates" that make the experience worse. Thanks for the suggestion though.
- 02-03-2013, 05:27 PM #7
I see what you're saying. I'd encourage you to use the link I included in my previous post to make your suggestions to Google. Just curious, though--is it really that much more of an extra step for you to tap the playlist and then double tap the song? Because what you describe as your old method was still two taps--one tap to bring up the playlist menu, and then another tap to play it.
- 02-03-2013, 06:40 PM
Thread Author #8
You're right. It's not that big of a deal...the extra tap. I just don't understand the advantage to changing what was already working. The album art is a bigger deal and I did as you suggested. Thanks. Any suggestion on a simple way to pin music to the ext sd card?
Problems with Google Music
By HeadAcheJoe in forum Motorola Droid X2Replies: 0Last Post: 09-30-2012, 05:22 PM -
Anyone know how to fix my google music problem?
By mcdaking84 in forum Verizon Galaxy NexusReplies: 1Last Post: 06-24-2012, 04:34 AM -
By tazzz013 in forum Barnes & Noble Nook ColorReplies: 2Last Post: 11-19-2011, 09:15 AM -
Problem syncing contacts and google music
By MrTyC in forum HTC EVO 3DReplies: 2Last Post: 08-09-2011, 08:07 AM -
Google Music "first track" problem
By Jack in NC in forum Android ApplicationsReplies: 15Last Post: 06-25-2011, 11:32 PM
Reply
