Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By B. Diddy
    Default Nexus 7 What to do...
    I hope this is the right fourm.. Well My tablet will be here in aout 3 hours... Excited!. Is the nexus 7 in your opinion a good Gaming tablet... I got the 32gb version i prob wont even use it all but its nice to have..... I am not going to root my device.. I never did it before and dont want to do it with my 250$ machine lol..... Do you guys think it will still perform well on Racing games Or combat games .. Or i should just say any game......... From 1 to 10 how do you think it will perform....
    Also Im considering downloading Advanced task killer so i can keep my memory all focused on 1 game.. will this help or is the task killer just a joke?
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    14,038 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Default Re: Nexus 7 What to do...
    Can't speak on behalf of the tablet itself but I wouldn't bother with the task killer. Android does a great job of managing its apps and memory. Even with task killers and using Androids own DISABLE feature within settings some system apps will still over ride and run because they have been designed to.
    Plus task killers usually at the heart of most problems when things go wrong with someones device.
  3. #3
    Nexus 7 rocks when it comes to games. I have Asphalt 7 and GTA3 , which perform flawlessly. There's a good reason why Gamestop sells them!
    And I agree with the above, task killers are not needed.
    Sent from my DROID RAZR using Android Central Forums
    quicksilver53 likes this.
    Ah ok thanks guys... I wont use the Task killer i just figured it would be good cause it has over 240k 5stars in the google play store :P
  5. #5
    The main reason to use a task killer is to stop a misbehaving app. The tough part is figuring out if an app is misbehaving or not. Closing apps just because you think it will save battery or speed up processes is usually counterproductive because of how Android is designed.
    So would it hurt it if i installed it or just leave it be?
  7. #7
    Quote Originally Posted by Kirrasbank View Post
    for now just dont install it. if you have issues then install
  8. Thread Author  Thread Author    #8
    Ok. thanks..
  9. #9
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Well, it's going to be taking up resources to save resources. I was just working with someone I know on their phone. It's older, but, it was running slow. Removed the task killer and the performance increase was noticeable.
  10. #10
    A-android-B's Avatar
    Posts
    ROM
    it changes so much
    Awesome for games the tegra 3 inside this baby flies and plays many games with lagless performance with the graphics settings turned all the way up.
    tea candles are the duct tape of candles
    beamed from the mothership...
    but its only a proxy for my
    lubuntu 12.04
  1. Replies: 15
    Last Post: 04-24-2013, 03:02 AM
  2. Nexus 10 locking up and freezing,,,,, not sure what to do ???
    By Davyo in forum Google Nexus 10 Tablet
    Last Post: 01-01-2013, 08:10 AM
  3. What to do when I buy my Nexus?
    By Josh515 in forum Verizon Galaxy Nexus
    Last Post: 12-09-2011, 06:18 AM
  4. getting a Nexus S - what to do or get first?
    By Kyi in forum Sprint Nexus S 4G
    Last Post: 08-03-2011, 10:24 PM
  5. My new nexus one is a lemon, what to do?
    By vonhoene in forum Google / HTC Nexus One
    Last Post: 05-28-2010, 12:58 PM
