Results 1 to 4 of 4
    djjeffa's Avatar
    Posts
    Global Posts
    96 Global Posts
    Default Are there any battery health apps out there for nonrooted phones.
    I got EVO LTE 6 months ago and got a full day out of it now I'm down to a half day I don't see anything draining it so I'm looking for an app that will actually tell how many amps the battery holds so I could compare to what it should have new.
    Sent from my EVO LTE using Tapatalk 2
    get in da mix
  2. Thread Author  Thread Author    #2
    djjeffa's Avatar
    Posts
    Global Posts
    96 Global Posts
    Default Re: Are there any battery health apps out there for nonrooted phones.
    250 views and nobody knows? I'm guessing there is no such app, I remember there was one for web os (palm)
    get in da mix
  3. #3
    To tell how many amps a battery is capable of, you have to load test it, which (ironically) drains part of the battery. What you probably want to look for is the mAh (milliamp hour) rating for yours for an idea of strength. A simple google search should bring that up. Every battery monitor app I've seen only shows the voltage level, which does drop during use. I think those may also pull from what the phone itself reports and don't read it independently.
    If you're having drain issues, it could be the battery going bad if it's old, or you maybe have some apps that have background services working. A good example would be a weather reporting widget that access the net (a big power drain in itself) often to keep conditions updated.
    djjeffa's Avatar
    Posts
    Global Posts
    96 Global Posts
    I'm trying this
    Battery monitor widget
    get in da mix
  1. Replies: 1
    Last Post: 01-17-2013, 06:15 AM
  2. Replies: 16
    Last Post: 05-25-2012, 08:06 AM
  3. any audio boost app out there?
    By doctadunk in forum Motorola Triumph on Virgin Mobile
    Last Post: 11-14-2011, 12:58 AM
  4. Is there a Audio Amp app out there for Android?
    By aaronleong in forum LG Optimus S
    Last Post: 03-29-2011, 11:01 PM
  5. Any good tv apps out there?
    By vaporman1 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 01-15-2011, 12:03 PM
